DT466 injection pump on a DT414?
is it posabule to replace my tosted ambac pump on my 1066 with the bosch out of a late moddel 466, assuming i turn in the rack screw to keep from toasting my pistons,i hope it is as simple as changing the pump gear,timing cover and backing plate since boath engines are 400 series engines
Yes it will go right on. Depending on how yours was adjusted and how this one is set weather or not you need to turn it down. Lot of pumps are turned way up beyond factory specs so no way of knowing unless you dyno it or at least read boost pressures or exhaust temp's under full load.
Hopefully it is not off a truck engine otherwise it will work you need the lines,drive hub and throttle linkage.
