Dual fuel strainer
Mr. Mayor
If you have a dual fuel Farmall H, looking at the fuel strainer from above (tank side) with the shut off lever at 6 o'clock, where are the inlet from the small gas tank and outlet to the carb located?? I have one I'm not sure is correct. It has the outlet at 12 o'clock and the inlet at 3.
The outlet on a non-dual fuel H is at 12:00, and since the small starting tank is located ahead of and to the right, I think the 3:00 position would be about right, unless you have an early version which had the sediment bowl mounted to the small tank, but that's another story.
