DuAl Loader moves slow
bs2359
I have a IH farmall 656 with a DuAl 320 loader. The loader operates but is very slow and/or will not completely rotate bucket. It was low on hydrolic fluid, but not empty. Would it be air in the lines, a filter issue or what?
Low fluid levels can cause pump problems and also filter problems. So you need to be 1000% sure the keep the fluid level as it should be and to also service the filter once In a while. Also wrong type fluid can cause odd problems
Filter is on the right side sort of below the shifter and a bit forward. Bolt on plate. Been a couple years since I have worked on a 656 so cannot explain it better. If you post this in the Farmall forum you will get more help then up here. A few years back I had a guy bring me a 656 that had a bad ring and pinion gear due the sheared off ring gear bolts so I had to open it up and mess with the hyd system
It's also good to keep the system 2 or 3 gallons overfull. Your tractor really doesn't have enough hydraulic capacity for a loader. Lots of guys do it that way,tho.I wouldn't on a tractor that I needed for seroius/daily loader work. If you want to get 'serious',get a pto pump. The tractor pump only has 12 GPM and about 1400PSI at best. A PTO pump can have up to 21 GPM and probably 2000PSI.A pto pump/valves are cheaper than having to rebuild a hydraulic system on a tractor...
A 320 is a big loader. Mounts to the rear axle,right?More suited to a pto pump than tractor hydraulics. I had a 320 on an M once.That thing could lift the 'world'. It would literally pick up more than the rear end would hold down. Filled tires and 3 sets of wts per wheel.I miss it.
(quoted from post at 16:50:41 10/26/17) A 320 is a big loader. Mounts to the rear axle,right?More suited to a pto pump than tractor hydraulics. I had a 320 on an M once.That thing could lift the 'world'. It would literally pick up more than the rear end would hold down. Filled tires and 3 sets of wts per wheel.I miss it.
I bet you do! Maybe this old 656 will be just as powerful someday :D
