dual power on 5610
what size fuse is used on the dual power on an early model 5610. I bought this tractor last fall . I have several other blue fords and none have the dual power. Dealer couldn:t. help, Thanks ,TC
I put 10 amp in and it worked a couple of times. I replaced the toggle switch at the same time/ I t seems to be iin low now. {f I could get it high I would leave and not use it. I assume it like an Oliver and high is direct. Thanks for the reply.
Upvote 0
It takes 12V power to keep it in high. If the fuse blows or you have an open in the circuit, it defaults to low. And yes, high is direct drive.
Upvote 0
