"Dualing" a pickup question
Brad Gyde
Hey guys,
I was wondering what it'd take to put dual rear wheels on a pickup.
I want to do this because I found a super nice utility/service box for my pickup for REALLY CHEAP .. Problem is, the new box is 10" wider (off of a dually Ford) Than the other box I picked up with a lot of rust and good intentions to fix.. But I could scrap the rusty one and pay for this one, and have cash left.
I'm sure I could just put the box on a srw and call it a day, but to me, it would look stupid.. So, I can either dual the truck, or cut the bed and remove the "extra" 10 inches.
My theory is that with dual rear wheels I could carry a few more pounds (and maybe not wear out rear tires so fast)
Both my Fords have the long studs, like I assume you'd have to have for duals (as I am undecided which truck I'd rather put this bed onto). I know I'd have to change rear rims.. But I was told the axles on a dually are different width than a srw.. any truth to that?? (sounds like BS to me)
Any info appreciated.
Brad
Need spacers, putting dual rims on a srw pickup (non cab chassis) will cause the tires to rub on the springs.
Up front need dually hubs if you want to run dually rims all around.
Arrowcraft I think make the spacers.
must be the new trucks, ive put duals on the back of 3 different pickups thru the years, never had a problem with wheels hitting the frame, did have a problem with 1 that still had a pickup box on it the tires were hitting the fender wells but i always take the factory box off, their just too flimsey for my uses
This truck has the short Utility Box,If you look hard enough you might find the short box to fit between the cab and the box. This one may even be available if you're anywhere near central Wis.
