dually rim lug patterns
dentvet2
Does anyone know of a good chart for dually rim lug patterns. I'm wondering if I can put a larger rim like a 19.5 off a chevy 10 bolt pattern onto my old ford f450 truck. it has 10 lug rims taking 16 inch tires. I know some of the older HD 3500 trucks also had 10 lug rims. Some newer fords had 10 lugs but i think they might be metric patterns not suitable for the older F-superduty. But, i can't find a chart to compare all the lug patterns, any help? thanks
Just simply measure across the bolt holes for the diameter or use a cardboard template and trace the wheel pattern then cut it out like making a gasket if it fits on your hub it's right.
The bolt pattern is the same (10 on 7.25"), but the center bore of the wheel is different, you F-450 is 5.46" and the chevy wheels are 5.25". Rickson truck sells 19.5 wheels to fit your truck but they are very expensive, $220 each. If you have a source for the chevy wheels get the centers machined out to the correct size, the 19.5's really make a difference in the truck.
Ben
