Duals for 7000 row crop
"t guess"
You can probably find 16.9 X 34 duals.
I bought T-bars, as I was told they are one of the best designs.
Good luck
Brian
IF you can find 16.9x34, they will probably be
cheap. But they aren't very common. They also
won't help until the inner tires are into the mud
some, as the sidewalls are shorter.
You will need some type of clamp-on, or band
duals, as 7000's have flange axles and won't
accept axle-mount duals. The pic is my 7600 with
cast-center power-adjust rims and clamp-on duals.
(I have duals for my 7000 also, but no pic...
identical set-up)
Brian- I didn't have any pics showing the eyes on
my 4600. I'll take a pic and post if you haven't
gotten that figured out.
and T-guess,....
Welcome to the board (unofficial welcoming committee)
Sheez Louiz, FF, looks like a bugger if get a leak to have to pop off. Can't be any fun to have to line back up after taking apart!
I've only had 1 flat flat inner tire while the
duals were on (a blow-out that left a foot-wide hole
through the tread), and 1 flat dual. It's really
only a 15-minute job anyway - I made sure I bought
duals with clamps that can go anywhere around the
rim, not ones with bolt holes that have to be lined
up with the eyes. 34" aren't bad, and 30" are pretty
easy, but those 20.8x38" are HEAVY! Only move them
with the loader.
As far as where to purchase... many dealers will
have duals on hand,but those will be relatively
expensive. I've bought 5 sets at auctions, with
prices ranging from $350 or so for the 20.8x38's
with some hardware to $10 for a set of 18.4x34's
with a broken valve stem and no hardware. My
16.9x30's were found through a want ad - think I
paid about $300 for them will all hardware.
If there aren't any auctions with duals listed
coming up in your area, try craigslist (or
searchtempest to look at all craigslist ads within
whatever distance you're willing to drive to get
them).
Thanks again, I just found this site & thought what better place to find help & answers. Its a pleasure talking to FORD people. I'm sure I'll need more help as time goes on.
T guess and von Krom, Welcome to the board!! (unofficial welcoming committee)
Definitely some smart blue lovers here with tons of experience. Am sure they will help if can when the time is needed.
And don't be afraid to post pics of yours! We love to see them!
(quoted from post at 13:04:24 03/27/11) need suggestions, pictures would be great, & place to purchase.
thanks
................ A heads up for you,IF you have the cast iron wheels go with it,IF you have the stamped steel wheels forget it,we had a 1975 7000 we bought new with the stamped steel wheels and we put 18.4/34's on it,in a couple years disking on 250 acres the D*M wheel on the right side cracked at the lug nuts,the wheels darn near came all the way off,we upgraded to a TW 10 and put 18.4/38's on it and never had an issue with clamp on's,you have to watch 4-5 and 7000 ford's,they come both way's,stamped steel and cast iron, the steel dish's are not engineered for clamp on's!!!!!, as a side note we also had a 1975 New Idea Uni 705 diesel,sheller,picker and chopper,it had the 730 4 row cast iron snaping roll head,(4200#'s by it self) for picking or shelling ,on the left side where most of the weight was with the cab and engine and grain tank they had an optional ring for the stamped steel wheel where you put the thick ring in the wheel BEFORE you put the lig nuts on to prevent cracking of the wheel,the heavy/thick ring spred the load/weight over a greater area..........
Thanks for the heads up. But I'm comitted now, I Have purchased & have the painting completed, found a set fairly quick to my surprize. My reason for the duals is I have about 50 acres to bush & bogg (crp) ground, I plan on pulling a 7' wilbeck 24" blades. This may all be wishful thinking on my part But i'm going to give it a dang good try. When everything is complete I plan to post pictures. Give me your thoughts on my plan.
