Dumb wheel question
Stephen Newell
Why do they put the valve stem in the inside side of a wheel on a tractor. I finally got feed up with mine and moved them to the outside.
Depends on the application, probably less likely to get knocked off on the inside. I recently changed wheels and tires on my JD mower/conditioner. The book says to make sure the stems are out to avoid being knocked off by crop.
I move them to the inside when I can. Cows like to grub on them and they'll shear the stem off.
No particular reason.Hwever it was to offer some protection to the stem.You can put then any position you like and be 'correct'.However,I once ran over a hay bale.It got wedged underneath the tractor and ripped the stem out.I lost air and fluid in a big hurry! LOL
Some rims have holes so they can have the stem on either side,if you're adding wheel weights you have to be real careful not to hit the valve stem with a weight.Old loggers that skidded with tractors welded a piece of pipe around the valve stem hole to protect it.
lol ,. that's what I thought ??,, NEWBIES ,, aint nuthin worse to be rasslin' a wheel around trying to line up holes and bolts and snag the valve stem , rite after you put in a new tube ,,. btdt ,
And, with vineyard fenders on some tractors, it is more likely you can access the stem on the inside without removing anything, as compared to the outside. I realize that is probably not your situation, but it is for some of us.
Swapping side to side would work on turf tires or something like that, but if the're ag treads seems like they'd be backwards.
When I was a kid, one of my jobs was as "valve stem monitor". When we would grind feed and then fill hog feeders, the hogs would quickly chew the valve stems off of the tractor and grinder. When we swapped to the 966 for grinding I didn't have to worry about the rears. The hogs weren't gutsy enough to go under the running tractor to get the stems on the inside.
I'm more likely to brush against junk on the outside of the tire trying to get close to something, rather than run over something and hit the stem inside. Not that it matters - my chore tractor has them on the outside.
Was helping a friend do some field work years ago. The dealer was coming to get the tractor for some reason so we had to remove the clamp on duals. The first side we removed we removed the valve stem also.
While I've only seen it happen once, it has happened.
I saw my brother take a dual off one time and there was a round ball of dirt that had been rolling around in there, hard as a rock. It would have taken out a valve stem.
While on the subject, I've seen stems protected by a short piece of tubing welded around it.
Just in case anyone decides to do this, be absolutely sure to deflate and break down or remove the tire first!!!
EXPLOSION
I guess I am lucky then. I have probably knocked more off, working on them than during the use of the machine. The stem on the inside does suck if you are hauling them and have to get some air out of the tire for height.
I show that exact video to my students every year. Several years ago I caught some welding students bouncing their tires inside the welding class from a truck so I went straight over and told the instructor about the video. Needless to say we dismounted the tires first for them.
I never considered explosion, I waited until I needed new tires and had the old ones removed before modifying the wheels. I figured the heat would ruin the rubber tire welding on it. Anyway I welded one of those knock out plugs from an electrical box over the hole on the inside of the rim and then filled the hole with bondo and painted it.
