Duraspark in a 2n?
stryped
I just wondered if it was possible to install the guts of a 4 cylinder duraspark ignition onto the breaker plate of a 2n front mount distributor along with appropriate module to have an actual Ford electronic ignition?
Basically using junkyard parts instead of purchasing an aftermarket electronic ignition unit?
(quoted from post at 10:26:44 11/02/21) I just wondered if it was possible to install the guts of a 4 cylinder duraspark ignition onto the breaker plate of a 2n front mount distributor along with appropriate module to have an actual Ford electronic ignition?
f I recall correctly. Ford has called several different designs 'Duraspark', so to even begin to answer such a question, it would have to be narrowed down to specific units. I expect that some machine work on distributor shaft will be necessary, even if space allows the remainder.
(quoted from post at 07:26:44 11/02/21) I just wondered if it was possible to install the guts of a 4 cylinder duraspark ignition onto the breaker plate of a 2n front mount distributor along with appropriate module to have an actual Ford electronic ignition?
have an article on using the Duraspark but it look's like I need to use a computer to share it. I've done it with an FE points distributor and and also used a GM HEI module. I like your idea better of staying Ford.
(quoted from post at 14:55:39 11/02/21)
hatever you do , avoid Ford Motocraft TFI module (1983-1995) as millions were replaced due to failure in a class action settlement. Ford payed for labor, towing, parts, etc.
What about a 4 cylinder magnetic pick up fanned on the breaker
plate and a home made reluctor wheel pinned on the stock distributor
shaft? I will admit I do not 100 percent understand how they work but
wondered if it were possible
(quoted from post at 14:44:17 11/03/21) What about a 4 cylinder magnetic pick up fanned on the breaker
nything is possible with enough time, money, skills, etc. Enough money will buy the rest.
