Dynahoe 120
rmboyus
I just picked up a Dynahoe 120 for dirt cheap. It has a Ford gas motor. I m looking for information and parts. It needs a fuel pump and the brakes need to be fixed. Does anyone know what size ford gas engine it is and where to get brake parts as in wheel cylinders from? I m looking for any info on these machines please.
You should be able to get brake parts at NAPA. I don't expect they will have them by application but they can be matched up. They used common parts for the brakes. Casting numbers from wheel cylinders and Master cylinders can help. Take the old ones in with you.
The engine is likely a 172 or a 192 Ford. I think those were the ones they used. At least some had an ID tag glue on the rocker cover.
