Dynahoe value $$ ?
Found a Dynahoe backhoe I believe it to be a C.. 3-53 detroit runs, few hyd. oil leaks from cylinders lots of welds, buckets are worn out..tires pretty rotten.. what is it worth? can I still get parts? Thankyou
I would be a little leary of buying the Dynahoe. Years ago I worked on one and the clutches were shot. There was a plate on the unit that identified it as being a Borg Warner. The problem was B-W no longer supported it. Finally found parts thru an obsolete parts dealer. $$$$
