E engine and WC engine timing cover question.
redd720
I got me 226 E combine motor that i am going put it in unstyled WC for pulling. I have 201 WC engine with timing cover on it. I have to swap the 201 timing cover on 226 E motor. My question is: What about crankshaft oil seal? which oil seal i can use on E motor? 201 or E motor seal? I am going to get new oil seal but i don't know which oil seal.
Will D17 timing cover work on unstyled WC frame?
Tracy
You can actualy use the timeing cover for the gleaner engine, mine had a plug in the hole for the governor arm , just knocked it out and put the busching and seal in. the prob i ran into was the two bottom bolts for cover were a different size and the tractor cover would not fit.
