I've tried searching this subject, knowing its been talked about in the past, but not much luck. I have a 1953 wide front SC with Eagle Hitch. I have an 8-foot back blade, CAT 1, I used when I had my Oliver 1550. Hook up width/pins measure such that it matches Eagle Hitch width. The left, claw, on my EHitch has been slightly damaged and does not, close, quite as much as the one on the right, so it would be a little loose over the CAT 1 pin. Right side is fine. All parts seem present. Any thoughts/suggestions about trying to get this set up working with my SC? The only real need to, work, my SC is to back blade a large gravel drive way/parking area and, more especially, to blade back the large amount of Maple and Pine tree droppings that occur every year. Pretty light retirement work for the SC I think. And she and I would both enjoy it together if this will all work out. Thank you for comments, Dennis in E WA state.
