sbs
I have a John Deere 44H plow and I need help in locating new parts. Specifically 2 moldboards NGP214, 2 Shares 217, and 1 each landsides 8214A and 8215A. I seen the part numbers on cresent forge and shovel. Called the number with no luck so looked in archives and seems you know a little about the circumstances of the company.
Any help would be greatly appreciated.
Unless you are wanting to keep the plow original, why not just convert it to High Speed bottoms? All you have to do is remove the two large bolts holding the frog and bottom assembly on the standard and replace with a HS bottom assembly. It will bolt right on. Wear parts are much cheaper and the plow will do a better job and pull easier. Plus, it will be much cheaper to do this. Mike
