I have an early Ford 8N with the front distributor serial number 8N-7006. The tractor runs great but he governor housing cracked and was leaking oil. This tractor
does not have a proof meter. I checked online and could only find governors designed for a proof meter. However, the description of the governor indicated that it
could be used for older model 8N's without a proof meter (there is a metal plug screwed into the proof meter hole). I purchased one and installed it on the
tractor. It does not work. The governor basically does nothing and the engine always runs at full throttle. I was allowed to return the governor and was sent
another one, just in case the first one was defective. The results are the same; the motor only runs at full throttle. Any information regarding this issue or
just ideas and information would be very much appreciated.
