earthmoving DIY
drmiller
Hello all. I need to raise the earth a little for a 400' driveway and to make a pad for a large greenhouse.
Should I use a box blade or other implement, or should I just leave it to someone with a dozer?
Thanks in advance.
For the driveway, think about hiring a guy with a grader or a someone who can run a dozer really well and make sure you have a slight crown to the earth before putting down your gravel (assuming you're doing gravel and not straight to asphalt). It makes all the difference to have some drainage of the water off the road surface.
if youre any good at plowing,you can plow a few rows together and grade it smooth and have ditches for run off...you need a crown on asphalt too so water runs off.
good operator with a dozer or maintainer should be able to do work described in less than a day under decent conditions.
