Fletch3130
Good morning!
On my beloved 1979 3130, I had to remove and replace the main drive shaft seal on the high pressure radial pump (34PP1) so I opted to replace all the seals while I had it off the tractor. Problem is I did not take a pic of which ports the electric de-stroke unit goes in and in what orientation the de-stroke valve should be in. the top of the stroke control housing is self explanatory as there is only one that will fit, but there are two smaller ports on the right side. one had a plug, and the other had the line for the de-stroke unit. does anyone have the drawing or schematic or instructions that would show how this goes back together. Also, do the 4) 1/2" cap screws that fasten the stroke control housing onto the front of the pump need blue loctite or just torque them to the 80 ft/lbs per my I/T manual? thank you all in advance.
Devin
Devin
