Electric Fuel Pump?
TimWafer
Anyone have a recommendation for a decent quality low pressure electric fuel pump. I would like one with threaded inlet/outlet rather than the formed barbs. Its for a Wisconsin VH4D engine.
Most all the ones I have found online have dismal reviews with about 25% saying they failed initially or within a short time.
I have replaced the mechanical one already and its not in an easy accessible location. Hate to get an electric that's just going to fail quickly as well.
The original mechanical one lasted 30 years but it was always a beast to start when it was hot. New mechanical one lasted a week.
Thought maybe an electric one might help starting when hot.
Thanks guys. Looks like the Facet pumps have much better ratings so I will try one of them. Knew someone must make something better.
(quoted from post at 11:40:44 05/19/20) Thanks guys. Looks like the Facet pumps have much better ratings so I will try one of them. Knew someone must make something better.
Yes, the Facet pumps are good.
Do you know what output pressure you are looking for/what's best for your engine?
I would GUESS one of the lower-pressure units.
You may be able to resolve a couple of problems at the same time by relocating that fuel pump
to a better location. Trouble starting when hot could be caused by the carburetor getting overheated,
in which case you need to provide space and cooling air around it. If it is the fuel pump getting
hot, relocation would help that and make future replacement easier. All you would need is a longer
electrical wire and fuel line.
