(quoted from post at 16:54:35 02/01/20) Here we go again.
Four wire yes, [b:bfa79243b3]three wire no[/b:bfa79243b3].
(quoted from post at 04:53:05 02/02/20)(quoted from post at 16:54:35 02/01/20) Here we go again.
Four wire yes, [b:d8606b7823]three wire no[/b:d8606b7823].
Please explain to me why he cannot convert a three wired 220 outlet to make it 120.
You mean that I can not use any wire that has a Black (hot), White (netutal) and a bare ground on a 120 volt outlet?
Gotta go and warn the town that 1500 houses are about to go up in smoke for using three wire 120 outlets..
Geeze..
If it is a three wire outlet just replace the breaker with a 120, connect the black to the breaker, white to common and the bare ground to ground. Then wire the outlet correctly. Just as others have suggested.
(quoted from post at 16:52:55 02/01/20) I have a 220 plug that was for a ac. The 220 plug isn't used any longer. Can I make for a 110 plug using existing wire?
