1950 8n front dist. 6v system . No start. Been through the distributor 3 times making sure everything is working properly, points adjusted to 15 , did all the continu tests (points open, points closed , coil off and finally coil on ,and everything checks out. Put it back on tractor still no start. Check battery.. 6.43v. check key switch, on position.. 6.43 on both sides of switch. Check resistor key on.. 6.43 on both sides of resistor. Check from battery ground to top of coil..6.43 with key on, drops to between 2.4 and 4.3 when I hit the starter. Run jumper from battery hot lead to top of coil and tractor starts and runs. I’m at a loss as to what to do next. What am I missing?
