Hi All,
My 1956 TE20D stopped running for no apparent reason in August last year. I have spent ridiculous hours trying to fix what I now know to be an electrical problem and one that appears to be completely weird.
Just for the record, new points, rotor arm, distributor cap, high tension leads, start initiator, ignition switch plus the coil is tested and sound. I have the full manual and have run the tractor for 24 years so I'm not a newbie. I think it unlikely that I'm doing something completely stupid. ;-)
I've read numerous articles and watched YT videos until I'm square eyed.
I now have good spark to earth over about a centimetre from the coil's high tension lead.
However once that high tension lead is fitted to the centre of the distributor cap, the spark disappears somewhere on turning over and does not spark the plugs at all!
So close but so far.
The new quality multimeter confirms continuity from the four distributor terminals to the spark plug electrodes as well as continuity back to the coil from the centre of the cap.
Has anybody any idea what on earth (I guess it must somehow be a earthing problem) is going on within the cap and how to fix it?
The grass is now so high I can't see the topper!
Thanks in advance,
Paul
Thanks in advance,
Paul
