electrical power thru starter switch to starter
have 1900 Ford that will not turn over after turning over a few times the switch would not energize the starter or the starter is locked up.
need to know best way to check starter and switch
without hurting my starter.The battery is ok.
The hot lead to starter was hot to hand afterward
You probably have a solenoid on the starter that is part of the power supply circuit to the starter. The solenoid energizes a coil that makes the connection of the power lead from the battery to energize the starter. So you have to make sure the solenoid is pulling the contacts together. You can usually hear this. If the key switch causes the solenoid to pull in, you know the key switch circuit is OK. If you can hear the solenoid bringing in the contacts and the starter doesn't turn, the contacts may be arced and dirty and have too high a resistance OR the starter is bad. To enegize the starter, use a pair of jumpers from the Battery to the starter AFTER YOU MAKE SURE THE TRACTOR IS NOT IN GEAR! iF THE STARTER OPERATES THEN REPLACE THE SOLENOID.
IF THE KEY SWITCH DOES NOT BRING THE SOLENOID IN AND A JUMPER WIRE FROM THE BATTERY DOES, YOU'LL KNOW THAT THERE IS A PROBLEM IN THE KEY SWITCH CIRCUIT.
Since I am not familiar with the specifics of your tractor, you'll have to figure out the details of running these tests.
Ditto what the others said. insuficient ground and bad connections can cause this.
many people like to put the ground wire from the battery right to a starter bolt to help with this.. etc.
post back.
soundguy
What would a small amount of water getting in the exhaust ports do? Would it cause the engine to lock up? I had the exhaust covered, but the pipe to the muffler had some cracks and when I removed it I found a little water in the exhaust port. We had about 5-6" of rain since I last used it and it sits outside. If it would lock it up by the compression on the water, what is the best way to drain it.
