macec3(TX)
5610 Ford Diesel. This morning I tried to start the 5610. Battery was weak and would just roll engine over slowly. Turned key off and starter stayed engaged as if the key was still on. Got wrench and pulled negative cable off battery. Put new ignition switch on and still had same problem.
If the ignition switch is OK, what would make the starter stay engaged and try to start the tractor?
Could this be caused by a weak battery?
