52 8N six volt side mount
Fully charged battery, no movement on the ammeter when cranked. Tested switch, it is good. Voltage at coil, no spark at test plug.
Changed the points today and broke off the copper contact strip. Haven't been able to locate copper to make a replacement. tried a short 12 gauge wire with connectors.
Is it safe to assume the rigged wire is the problem? If so, any ideas on a replacement copper contact strip? And if not the wire any other thoughts?
Thanks.
Thanks.
