My son purchased a house a couple of years ago, during a period when I had some health issues. Actually, when I told my son I was too tired to attend the inspection he sent me to emergency where they discovered a clot in both lungs. Now to the issue, recently he had a high electric bill, which turned out to be the electric heater a guest was running, turns out 1.350 times 720 times $0.20 = $194.00. But just to check for phantom loads I went over and did an amperage draw check on all the circuits. Here is where the trouble started, first it was a Challenger panel, second all the circuits with 14-gauge wire were on 20 Amp breakers and a mysterious circuit going to the barn was made up of a pair of 14-gauge Romex cables on a 25-amp two pole breaker. The house was built in about 1984 and it was typical 1984 residential practice with just the heavily loaded circuits on 12-gauge wire and I expect the 14-gauge circuits were fused at 15 Amps. At some point a later owner needed to add a two-pole breaker for air conditioning and another for a pump and converted the 15 Amp circuits to tandem breakers at 20 Amp. I removed the 25 Amp two pole and disconnected the circuits. After I get a look at how they get to the barn and what exists there. I expect to connect to single 15 Amp breakers. The advice I need from the experts here is all of the breakers except for a lone HOMI are Siemens QP including what appear to be the originals including the snap in main. The plan is to replace the 20 Amp tandems with Siemens QP 15 Amp tandems, ditch the lone HOMI and replace it with a Siemens single pole QP. My only issue is my research shows the proper replacement is an EATON CL series in the Challenger Panel but does say some Challenger panels used the Siemens QP. I know the Challenger Panels had issues, and the long-term plan is to replace the panel. I have inspected all the contact blades, and they show no corrosion or signs of overheating. So, Siemen QP or EATON CL?
