Electrical testing question
Bret4207
Pretty sure I have a dead short in a 23hp Vanguard in my skid steer after I "repaired" some wiring. If I disconnect the pos batt terminal and put my multimeter between the terminal and post and set it to DC 500ma I get a pegged needle. At 50ma it doesn't even move. I'm not sure I'm doing this even remotely right. Can someone give me some insight here please? That is with the switch off of course.
(quoted from post at 08:16:37 05/01/20) Pretty sure I have a dead short in a 23hp Vanguard in my skid steer after I "repaired" some wiring. If I disconnect the pos batt terminal and put my multimeter between the terminal and post and set it to DC 500ma I get a pegged needle. At 50ma it doesn't even move. I'm not sure I'm doing this even remotely right. Can someone give me some insight here please? That is with the switch off of course.
If you have an incandescent style tail light bulb handy 1156 or 1157 try putting it between the post and cable.
If it lights up bright and stays lit then you do have a draw on the system but not necessarily a dead short.
Could be as simple as a headlight or heater switch still turned on.
A dead short implies a direct circuit to ground with no load in between, symptoms would be lots of sparks, blown fuses, melted wires.
Bret4207,
Your meter may have different fuses internal for different amp ranges ( cleared or burnt resistor for that range), thus further messing with your troubleshooting.
I like the light bulb idea, eliminates the odd meter reading.
D.
You need to test with the meter on the 2a or 10a scale. On my meter this requires
putting the positive lead into different port on the meter, and then setting it to the
appropriate scale. I would use 10a first and then back down to the 2a scale, if 10a
gives no reading. On about anything without ecm's, pcm's, bcm's, (computers), you
should get no draw(reading) with everything off. Above 1/2 (.5a)amp will drain battery
in a day or two. You do need to know if the meter is reading, so check with key on or
the lights on(10a scale). There is a fuse for these 2 scales. 50ma is way to low to
consider on a 12v system. Mark.
Try disconnect the voltage regulator and retest. Some voltage regulators actually draw a tiny bit of current to make their diodes work.
(I usually test on the negative side of the battery.)
If that doesn't work, try disconnect the engine from the chassis wiring harness and see if that changes anything. If it goes to zero your
problem is on the engine.
1/2 amp is 500ma 1/20 amp is 50ma, so the meter is suspect for pegging at 1/2 amp, and not moving
at 1/20. But. As below, the real max draw when things are shut off on non-computer controlled no
radio equipment should be about 50ma to zero. The light bulb will glow if there is maybe 200 ma.
it will be bright if dead short. Jim
In my opinion the filament of a 1157 bulb as suggested can carry to heavy of a load for what you are checking. I
use an old KD brand test light with an incandescent bulb ..not LED...picture. In a pinch I would recommend a
194 bulb instead of the 1157. A good battery will run a 194 bulb couple days and still start a vehicle. Have you
ever left your lighted glove box open accidentally? Although as others have stated a draw that would make a
small bulb like a 194 glow brightly is not acceptable.
It's not a dead short.
A dead short results in an instantly blown fuse or a smoking hot wire.
You have some accessory staying on, or possibly a bad diode/regulator on the engine charging system, or something in the electronic control module (if equipped).
Start with he simple first. Try unplugging the engine harness. If that removes the drain, look for a bad regulator or diode, whichever it has.
If that's not it start pulling fuses, one at a time, checking the drain between each fuse that is pulled. If one removes it, look at what that fuse powers. You can find the fuse map in the owners manual or online.
Find the control module, unplug it. If that removes it, you are on track, but do some further investigating before assuming the worst.
There could still be something simple, like an accessory, a bad switch, corrosion up inside a harness connector.
The test light is a handy tool for finding power drains, but it sometimes can lead you astray. Some control modules need time for the caps to charge and things to time out. The test light is not enough to make that happen, and it will sit there indefinitely showing a drain. That is where you need the DC amp meter.
When using an amp meter, always start with the high setting and work your way down. The small cheap meters are not always over current protected and will instantly fry if connected to a too heavy load. Once the system is connected through a readable amp scale, the system is being powered sufficiently to let everything time out, then in a few seconds the draw will drop to near zero.
If the battery connection is drawing a visible spark with a pop, that's a significant load and not likely something in the control module electronics. Also not something you want to connect with your meter. Look for an obvious draw, like lights.
I appreciate everyones replies. There are no lights, computers, heaters, blowers, fuses, nuthin'. It's just a 23 HP Briggs Vanguard sitting in a 1960's 444 Bobcat. Standard 15a internal alternator that had a broken wire I think I fixed. It also had a bad relay that was supposed to shut off the fuel solenoid and ground the mags. It wasn't grounding the mags at all and I bypassed it as I couldn't find the relay anywhere. That involved 3 changes of mags with accompanying engine removal! So I just used a switch to ground the mags. The ice took out a lot wiring a couple years back and I got it back together as best I could. Trying to find this specific wiring diagram from Briggs has been a total waste of time. It apparently doesn't exist even with the the right numbers off the engine, just like that phantom relay. When I say dead ground I mean not an intermittent ground. Sorry for the confusion. There is no spark to be seen at the terminal/post interface. I'll see what else I can find. Thanks!
My guess is you've blown the fuse used on the 50 milliamp scale, or else internal protection is preventing the meter from working on that range.
It's best to look for shorts with using the DC volts scale; a 12 volt reading indicates a "short", although that short can be very small. Digital multimeters have very high input impedances, so just a few milliamps will be enough to get a 12 volt indication. Disconnect the voltage regulator, as it typically draws enough current with the switch off to get a voltage indication. If you still see 12 volts after disconnecting the regulator something is seriously wrong.
(quoted from post at 07:06:56 05/02/20) My guess is you've blown the fuse used on the 50 milliamp scale, or else internal protection is preventing the meter from working on that range.
Thanks Mark. Mine is analog, but I'll try it.
Who ever recommended going to 12V scale and checking the regulator is the winner/winners! The regulator was one of the things I fixed and it appears it must be faulty as it is drawing 1.4V just sitting there. I'm assuming it's bad. I don't think it's been charging for a couple years, so that might be the issue. I'm thinking the regulator should not draw anything with the engine off? When it was new it charged and didn't draw down the battery. 1.4V isn't a lot, but I don't know how many amps it drawing either. It used to go a month or more without the battery even being weak.
(quoted from post at 00:53:26 05/03/20)
Try pulling the cover off it and cleaning the various sets of points that are in there. Also make sure none of them are stuck together.
This is a "solid state" circuit board type regulator. Ain't no points to check! Thanks for the idea though.
Update- I've found that while I had a 1.4v draw between the pos cable end and terminal, when I go tot he neg end and do the same I get a full battery charge voltage, eg- about 13.2 volts. The voltage regulator wire runs to the battery side of the starter solenoid and everything I have shows that to be the correct spot. The charging system looks to be working according to my load tester. I'm assuming the Voltage Regulator is bad as there are no other connections going to anything but the stator and solenoid. Unplugging the VR from the harness eliminates the voltage draw entirely.
Have I missed anything?
