electrolysis question
Bob N.Y.
Location
Norway, N.Y.
I am trying to derust the inside of a gas tank using electrolysis. This was suggested by a man I met at a cruz-in a few days ago. I have an old style battery charger, not solid state. The tank is filled with a baking soda solution. I am using a piece of 5/16 threaded rod through an old toilet flapper as the anode. The flapper insulates it from the tank. When I first plug the charger in, the meter goes to 3 amps. It drops back to zero in 20 minutes or so and the anode is covered with rust. I clean the anode and plug the charger in and the meter goes right back up to 3 amps. I assume this means the process is working. Question 1: Does the rust accumulation on the anode insulate it from the solution causing the amperage to drop to zero? Question 2: Does the the process continue even though the meter is reading zero amps?
Thank you.
I'm not an expert, but I think that you will need to use washing soda rather than baking soda, and also use an anode with more surface area than a 5/16 rod.
I've never read much about using electrolysis on the inside of a tank. There may be a reason.
There was a article in Red Power Magazine, maybe 8 yrs ago,according to that it worked good, but i never tried it !!
As said below, washing soda is much better at making an alkaline solution which is what you want, the reaction will always slow as the anode becomes covered. The dropping of amps is your sign that its time to clean, I always found a smooth surface is easier to deal with and only a quick wipe gets you back to working at its best. The threaded rod would take a good scrubbing with a brush to get all the surface clean every time.As for the last question, as long as you see bubbles and or foam on the top of the solution, things are still happening. I dont think Ive ever had one stop completely not matter how bad things had loaded up. Remember that it works by line of sight only, if your tank has a baffle the anode might not get the back side without some creative bending of the anode.
Some of my cleaning with Electrolysis
I found a piece of smooth, clean 3/4 inch rod for an anode. The charger went up to 9 amps when I plugged it in. Thank you to all of you for the advice.
(quoted from post at 11:16:24 08/07/21) I am trying to derust the inside of a gas tank using electrolysis. This was suggested by a man I met at a cruz-in a few days ago. I have an old style battery charger, not solid state. The tank is filled with a baking soda solution. I am using a piece of 5/16 threaded rod through an old toilet flapper as the anode. The flapper insulates it from the tank. When I first plug the charger in, the meter goes to 3 amps. It drops back to zero in 20 minutes or so and the anode is covered with rust. I clean the anode and plug the charger in and the meter goes right back up to 3 amps. I assume this means the process is working. Question 1: Does the rust accumulation on the anode insulate it from the solution causing the amperage to drop to zero? Question 2: Does the the process continue even though the meter is reading zero amps?
Thank you.
Plus 1 on washing soda.
You are smart doing that before using liner,I do and it take's less liner and seem's to work better. I have a tip that will alow reaching behind baffals and around corners. I use anodes rigged like this 90% of time because it make's it much quicker to hook up and go. I have four 1/2" pvc pipes in varied leingeths into which I drop #4 rebar for normal rust or #3 for heavy rust that would make it difficult to remove #4. I drill and/or saw as large and many openings as possible without weaking pipe enough to bust. One end has glued cap,other has fpt adapter and threaded cap. I solder 2' of stranded steel wire to end of rebar. Copper wire and brazing work but deterioate sooner. Wire passes through drilled hole in threaded cap,sealed with silicone and hang loose ready for charger clamps. No more tying and proping anode to prevent short circuit pluse anode can be easily moved around amongest parts in vat. Multiple cathodes(attachments to multiple rusty parts) and anodes can be used with heavy charger,golf cart charger or welder.
If electrolytes doesn't work. Try citric acids
My boy soaks rusty thing citric acid to remove rust. Let it soak overnight.
I would fill tank food grade phosphoric
acid and water. Let it soak overnight.
(quoted from post at 04:44:11 08/08/21) If electrolytes doesn't work. Try citric acids
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto96775.jpg>
George, which do you use citric or phosphoric?
