Electrolysis Question
OK_BobL
About how much of the 92% sodium carbonate (Pool Chemical, PH+) should I stir into each gallon of water to cook parts using probably about 17 amps (50 amp charger) using re-bar stock?
Bob
I used between 1/2 and 1/3 cup PH+ pool addative 100% sodium carbonate per 5g of water in my tank. it 'cooked' at 17.5a and worked nicely.. I use a few piece of scrap metal from my pile.. etc... I spaced them around the tank and used gator clips to wire tham all together and then to the + battery clamp.. thent he - clamp tot he work.
soundguy
Just passing it along. I think Dunk and a few others gave me this good info a few days ago. I hadn't set up an electrolysis rig in 20ys.. they helped me out.. so I just passed it on to you.. etc.
I cooked a rim in it this weekend.. looks great.. all the old paint came off and left pretty much mare metal and pitting where the rust used to be!
I'll prime with a rust converter and then paint it up before i put the tube / tire back on.
Got to weld up a calve stem hole first though..
soundguy
Soundguy, I've seen your work and it all looks good. I bought a 660 last August and am not ready to paint (lots of farmer fixes to clean up). She had two owners since new. The last (he died) had it most of the time. Engine has a fresh overhaul on it and converted to 12 volts. I got lots of implements with it.
I plan to use the original front wheel weights (16 inch) that still have most of the original paint on them, to practice with the electrolysis system. The farmer had taken them off and had a Ford 19-117 front end loader on it (manual dump) that I plan to take off, then I'll need the weights on the front.
Again, thanks for the guidance.
Bob
Hi souNdguy
How many bars, rods, etc. are required?
Is there a general rule of thumb?
Should cooking containers be plastic?
Will wire size affect the process?
I assume that all parts need to be completely covered.
I have fenders, wheels, and other parts I would like to clean up, so am being nosy!
Thanks in advance for any advise.
Brian
Wire size needs to be adequate for the current needs of the charger.. IE.. a charger should already be equipped with correct sized leads.
Parts do not have to be completely submerged.. but only the submerged parts will 'cook'.. etc.. but you can flip them.
the more sacrificial electrodes the better.. it's almost a line of site type arangement.
soundguy
