Electronic ignition on my tractor
lenray
The JD fellas have been really helpful.
I want to go with the electronic ignition on my JD 3010--Some info.
Have went from positive grd. to negative ground.
Replaced Generator with an Alternator.
Anyone know of the brand to use for a 3010 JD that is now Negative ground and with an Alternator.
Probably go with a new coil also.
If you have a name brand and part number that would be great.
Before you go to the pertronix website, get the number off your Delco dist. Then when you match that to a Pertronix unit, make sure you go to negative grd. When you get the unit #, try looking in YT parts and compare prices. Good luck.
I tried looking here at YT but can't find where the electronic ignition stuff is located.
Found the 12 volt conversion things.
Thanks guys for the info.
Old Pop...
HOW do you know it's a Delco?
IIRC, they used some Prestolites and maybe even a few WICO's
