Engine Block for an unstyled WC
I have one that I picked up for a fellow over eight years ago and he changed his mind. I am over in Edon Ohio if that is not to far away.
Any WC styled or unstyled, as well as any WD or WF block will all work. They are all the same block. A WD45 block will also work, but does not have the bolt on plate on the right side of the block. I have a WD45 block in a 1938 WC. Kip
Easy to find as others have said. What is wrong with the one you have? They are well known for cracking the deck between the cylinders. If the crack is flush put her back together. If it's something else, then you might need a new block, but I wouldn't be too worried about a hairline crack on top.
AaronSEIA
