Engine Block: Same or Different?
MOMule
Other than the bore, are the 3000 Diesel and 4000 Diesel blocks the same? Wanting to know if I buy a good used 3000 Diesel Block if it can be turned into a 201. Local dealers think they are different because the part # is different but admitted they were not sure. I am wondering if the part # is different because the bore is different. Thank you for any information you can provide me.
I've heard of people boring 4.2" blocks out to 4.4", but I gotta think that's not very wise. There's no way those two blocks were cast with the same wall thickness.
Knowing how many of the 4.4 blocks that I have had to have rebored and sleeved back to standard due to cavitation problems, I wouldn't think about it. I have had a couple of 3000 blocks bored but not that much. Some really good machine shops are set up to ultrasonic test blocks and could determine the wall thickness.
The sleeves for the 3000 block are only 4.32 O.D, so the manufacturer didn't even want you boring that block all the way to 4.4" just to sleeve it.
Thank you for the replies. I will not go with the 3000 block but am having the 4000 block bored and sleeved back to standard. Thank you.
