MF 265 diesel. When you turn the key to crank the engine sometimes there is a click then nothing. If you keep trying the key switch 8 to 10 times it may crank and run. I have unpluged the wires from the key switch and jumped them and get the same thing. I have tried cranking the engine by shorting the solenoid at the starter. No go.
Do I have a bad solenoid, bad starter or ??? Also battery voltage is checking as it should for proper cranking.
Thanks for any and all suggestions.
