Ring84
- Location
- West Virginia
So I bought a MH55 a while back. The engine was loose and I was told it hadn't run in 6 years. I got it running and using spark detectors on each cylinder it shows its firing on all cylinders. However, it has an audible miss-fire. I took the plug wire off of each spark plug to listen for a change and there was no change on cylinders 1 or 2 and the miss-fire got worse on cylinders 3 and 4.
I've tried to adjust the timing, the miss-fire only stopped until I drove the tractor then it started again. I also put new plug wires on with no change. Anyone have any thoughts on what the issue could be or something to check next? Thanks
