Engine noises?
550Doug
Location
Southern Ontario
On a Continental F162 motor that I recently picked up, I can sense at times a 'rattle' sound and at other times a small "squeal' sound both from the engine area. Is the rattle associated with oil problems and the squeal could be a belt problem? Are there any sounds that may preceed rod or bearing problems? What about burnt valves, or tappets, are there any sounds indicating these?
A rattle could be a timing problem,distributer too far advanced.A squeal more likely a sliping belt,such as power stearing drive belt.Valves wont make the sounds you describe good luck
could be loosing a bearing on a belt driven engine accessory, ie water pump, generator, ps pump too. loosen the fan belt and spin all the pulleys by hand feeling for rough spots.
