engine oil add on 48 WC
GRC
Where can you add "easily" engine oil to a 48 WC ??? The governer has a cap marked "oil"...is that where I can add engine oil...I"m a qt low ???
Thanks...
Do you know the engine oil capacity for a 1948 WC and is there any suggested oil weight to be used ???
6 Quarts. Years ago they used straight 30w and 20w in colder weather.
Today with newer oils 10w-30 year round will be just fine.
If your area has supper cold winters and you use your tractor in the winter say at -20F below then I would use the newer 0-20.
5-30 is also a good oil for normal winters that stay above 0 mostly in the high teens to mid 20'sF.
I use 15-40 in all of my old engines. they don't need the lower vicosity. They never asked for 5 or 10 weight oil to be used. Usually 20 or 30 wt.Bob
