I use 15w40 in all of our 2 cyl. John Deere's A,B,M,530-through 730's 60's, 620, 2750 , 3255.
But I use Motorcraft Oil since I also work for Ford Dealer.
The 15W-40 oil will be fine for that tractor. As far as brand, I would go with a high quality name brand oil, which is readily available to you. Mobil Delvac, Shell Rotella, Kendall, Cenex, are all going to be fine motor oils for your use, and are the first ones that come to mind which I have been around and used.
