Engine project question for soundguy
Devious
Hi Soundguy would you peruse my post to you on page two and see if you would care to reply. Just need your ideas on a couple of things. Devious
Backed into a pile of dirt and lost power. Did you dig the dirt out of the exhaust pipe or is it still in there not letting the engine breathe?
It did not hspprn that way since the three point had a box blade on it and the actual tractor did not hit the pile, just the implement that stopped it suddenly as I get the deal. He said it just would not function (Pull) but that was long ago. It has been sitting since. But the engine was still running well as he said when he parked it. Devious
I think this topic is in need of some light and cheerful dialog. I heerd of this old scruffy black prospector who came into town on his mule. A Young cowboy who had been drinking a bit asked hi if he could dance and he said no, and the cowboy started shooting at the old bellers feet and he started dancing for quite a while. Soon the six shooter of the young cowboy ran out of shells and he put it away and said You dance purty good old man. The OLD MAN eased back to his mule and eased a sawed off shot gun from his pack and shoved two shells in the barrels. He turned and asked the younster if he had ever Licked a Mules A--.? The cowbooy said "No Sir, BUT I Have Always Wanted To. Devious
if the engine runs but the tractor won't move:
does the pto work?
if so.. clutch is good.
if not, pull tranny or look in filler and see if anything in the trans moves with clutch no pressed.. if no.. clutch hub likely ripped out.
if pto works:
possible broke pinion hollow tube coupler under top cover.. OR sheared rivits on ring gear.. or 1 broke axle ( heck.. or 2 broke axles :) )
inspection cover in rear will give ya a looksee.
soundguy
Hey thanks Mr. C I appreciate the clues to start with. It is not running right now as I looked under the head and found good stuff. Just needed the things you spoke of for starting places. The broke pinion hollow tube was a mention and the rivets also but I will now get the dog in the hunt and try to make it walk and talk again. It is a 9 or 2N from the 30s or 40 with a 8N engine as its only stray from original I think. Later Devious
