Engine reassembly lube?
Looking for the general consensus on assembly lube. I'm working on a 404 engine in a JD4430 and I'm wondering what everyone uses for lube on the crank journals.
30W oil, lithium grease, gun grease, special assembly lube, as long as it's lubed.
I mix some engine oil with Lucas oil additive.. The Lucas makes the oil a bit sticky and it will stay in place...I keep some in a smaller oil can just for this..
I've seen it done all kinds of ways. I think as long as there is some kind of lube in there.
I went and got some Lubri-plate assembly lube. Looks like white lithium. I used to use a red assembly lube but couldn't find any without ordering.
