engine replacement
I have a nice litte 8 hp.Massey Fergusan that my "mechanic" changed oil in and forgot to add new oil afterwards. He is a sub-cantractor. Which orific do I insert this motor and is there a rebuild possible?
Twisted Mike
If you mean which orfice on your mechanic,grease up the eng & insert in largest avail opening,as far as rebuilding eng it may be possible & will be expensive,same is either a tecumseh h80 or hh80,1st thing to do dis-assemble eng & determine amount of damage,if eng needs a rebore,os piston set nla from tecumseh,although may be avail aftermarket for h80,if eng an hh80 piston set & most other parts still avail from tecumseh or aftermarket,os piston set from tecumseh run about $113,you'll have to see what parts you need & see what's avail & cost of same plus cost of rebore.Yrs ago I bought a basket case mf8 & put back together,eng was shot,bought a new tecumseh hm80 & installed with no problem,only downside is alt on eng a 1 wire output with inline diode,this type of alt stator will not work with existing rect/regulator,due to fact tractor didn't have lights & battery only used for starting,I just charged battery 2/3 times a month to use elect start,briggs does have some rect/reg listed for 1 wire alt output,weather they will work with tecumseh alt I don't know,rebuilding the h or hh eng will be expensive/time consuming,if you can get by useing the hm the way I did,you might want to consider that or check on ebay,you might get lucky & find a good used/rebuilt h/hh eng for a reasonable price
