ounds like you're describing my Kubota B7200. In my opinion (for what it's worth) no, running around from here to there under 2000 rpm's won't hurt it at all.(quoted from post at 18:09:24 10/14/22) I'm use to old tractors where 1200 rpm is wide open. I now have new one where 1200 rpm idle. Is 2000 rpm to slow to run tractor. Will it hurt it at 2000 rpm if not under a load. 2500 rpm is speed to get 550 Pto speed. It is 3 cylinder diesel.
(quoted from post at 09:41:28 10/15/22) I'm still having trouble listening to the engine run that fast sounds like it's ready to blow up Another thing I was wondering if the engine runs twice as fast why is it not used twice as much fuel
(quoted from post at 14:48:35 10/15/22) Interesting piece of trivia.
All Formula One engines are naturally aspirated V8s with displacements of 2400cc. Engines are restricted to a maximum speed of 18,000 rpm.
Jet engines typically operate in the range of 8,000 RPM to 9,350 RPM (high pressure compressor).
Who would have thunk a F1 engine runs 2X the RPMs of a jet engine?
(quoted from post at 12:05:04 10/15/22)(quoted from post at 09:41:28 10/15/22) I'm still having trouble listening to the engine run that fast sounds like it's ready to blow up Another thing I was wondering if the engine runs twice as fast why is it not used twice as much fuel
Almost all diesel engines are controlled by a governor which is controlled by the throttle setting. When the machine takes a load and RPMs dip just a little the governor pulls the rack linkage to increase the amount of fuel being injected, so that the RPMs stay where they are set for.
