Engine swap on 4630
Bought an engine that was in an 8430 and
planning on putting it in a 4630. I know I
need to use the 4630 flywheel but do I also
use the balancer off of the 4630 or use the
8430 one? Thanks
if your going to use the 4630 water pump you will need to use the 4630 balancer to keep your belt belt pulleys in harmony.
So I can use either balancer set up as long as I use the corresponding water pump basically. I wasn't sure if the balancers were set up to match the flywheels or how that worked.
Yes,,and I would use the 4630 balancer and water pump,, the 84 pump and pulleys are too large to work out well on your 4630...
so you know on the 4 wheel drive the bolts that hold engine to clutch housing screw into clutch housing. The bolts on 2wd tractors screw into engine block . not a big deal but a deal
