I am currently adjusting the timing on my 58" ford 800. I have located TDC on cylinder #1. I believe #1 cylinder is at the front of the tractor, furthest away from the seat, correct? Anyway, when I put the distributor cap on, with the points open(on the high lobe), the rotor is lining up about half way between two of the points on the distributor cap. The distributor can only go on two ways with the way the clips fasten it to the rotor/point assembly. No matter which way I rotate the rotor/point assembly or rotate the distributor cap it will not line up properly. Is the rotor suppose to line up directly on one of the distributor cap points when the lobe is on the high side and the points are open? Should I attach the #1 plug wire to the distributor point prior to opening or the one after closing? Hope I make sense and any help would be appreciated. Thanks. Brad
