Any good 2 barrel carbed 352 or 390 will do a good job in there..and are easier to find..
You will need to use the exhaust manifolds from the 352/390.
The Intakes will not inter-change either..FYI..unless you use the matching heads..the heat-riser passages are routed differently and will not match-up.
A good 460 would be an even better choice..would require a different bell-housing. The 4 barrel 460 is a Mountain-Mover..!!
Ron..
