y 971 did that, and as Rod said it was because the control valve stuck. I am not familiar with the English 4000 but on the 4 cyl. 4000 the valve can get hung up by putting a standard grease fitting into the valve, instead of a short threaded one. Once the damage is done you pretty much have to dissassemble it and clean up the scratches. It is not a tough job.(quoted from post at 19:10:39 09/20/11) I sure am glad we got on the subject of the British 4000! Mine left me stuck in the field today. When I went to turn at the end of a row, the steering wheel spun to the right and locked up. I had to break the power steering lines loose at the cylinder and pull the wheels back straight with a chain. When I started it back up, she tried doing it again. It took everything I had to hold the wheel still and shut it off. L looked in the big 2000-5000 manual I have and nothing in the steering section looked like whats on my tractor. I took the cylinder apart and it looked fine, I took the only valve out of the pump and it seems to be fine. When all this started, I had only been on it about 20 minutes and the cylinder, hoses, and pump were so hot I couldn"t touch them. Now for the big question: what on earth is wrong with it?
