Equilizer bars with equipment trailers ?
So.........while I was hooking my 28' camper up the other day, hooking up the equilizer bar system and anti-sway bar, I got to thinking that I've never seen anyone using those things for a tandem axle tractor hauler trailer. I understand that there is greater sail area on a camper, but would there be a benefit to using them?
Thoughts ?
Ive seen them used quite a bit, but not enough. I think the only downside is people dont want to take the time.
I pulled my 20 ft flat bed with a small Toyota PU (back when they only made one
size)and I used the bars all of the time. Now I tow with a 3/4 T Chevy. I still
use them with the camper,I like the front end, down not 3 feet in the air.
Camper and PU weigh 13,000#
With some vehicles the manufacturer requires the use of a weight distributing hitch to achieve the advertised towing capacity, regardless of what kind of trailer it is. My F-150 is a good example - it is rated to tow 11,300 lbs but without a WD hitch it can only handle 5000. Even my 2001 F-250 Super Duty was limited to the same amount. This is because it is impossible to properly balance a heavy trailer without overloading the rear axle if you don't transfer some of that tongue weight to the front axle. I have personally only used one once when I had close to 10,000 lbs to tow nearly 400 miles. I can verify that weight distributing hitches work great as the ride was very smooth and stable, even though both truck and trailer were loaded up to near their rated maximums.
I would think they could be a good idea
People can choose to ignore math, physics, and proven engineering principles but that doesn't invalidate them or make them go away. Doesn't keep some people from trying, though . . .
Unless lightly loaded I routinely use stabilizer bars with my tandem axle 10 K rated (with 6 K axles) when hauling. My load this past weekend was incorrectly loaded as I had slightly too much weight on the trailer. Everything turned out okay but my preference is too much tongue weight and then keep the sway bars tight. A good starting point is attach the bars with an empty trailer just snug and you will not have to do more adjustment 90 plus % of the time. I don't like to haul without them.
Maybe unrelated... I remember back in the 70s seeing an ad for a weight distributing hitch in an RV magazine. It showed a front wheel drive Olds Tornado with a large travel hitched to it with WD hitch - and the rear axle of the car was removed.
I didn’t read the fine print but I’m sure there was a disclaimer, and the ad published to demonstrate how the hitch works.
them equilizer bars have some advantage sometimes. Try going through a side ditch or uneven driveways and you will develop a bad taste in your mouth about them real fast
Frank, I saw a film from Reese Hitch Co showing the Toronado with the rear wheels removed, towing a trailer.
