erickson skid loader parts
jimvw
Need an axle shaft for my Erickson 25 hp skid loader. This one is a model 25-44 or known as the little Eric. This is also the same as a Ford CL20. New axle is not avaliable. If you know of one of these sitting around or wrecked out let me know. Thanks
Any good Machine shop should be able to turn one out for you.
Don"t know what it will cost, but as long as you have the old one for a pattern it should be possible.
Web search provided this.
http://www.hermanmfg.com/axles.htm
Go down to crawler dozer skid loader and do a search for Erickson. Axles have been discussed there.
When my ford broke, I also couldn"t find a replacement. Mine was broke right at the hub. My brothers shop was able to drill the hub and tap the shaft, re assemble and weld. that was 4 years ago. I will admit that I have been real careful about spinning the tires and turning on pavement. I also only put about 50 hours a year on it. Good luck.
