I have a '52 model TO30 that runs like a top, but the hydraulic lift has issues. First, the lift handle is way out of whack in the quadrant. It begins to lift about 2 1/2 from the bottom. From that position to the top it's really not doing anything. When I have a heavier implement like my bushhog or disk attached and pull the hand lever up the lift will raise all the way up quickly and then immediately drift back down, once it drifts down it will lift all the way back up and repeat the process of drifting down.
If I raise the lift handle slowly and stop it 2 1/2 or so inches from the bottom it will lift the implement and hold its position. Lowering the implement is kind of an all or nothing proposition. I can ease down on the handle about an 3/4 inch and it creeps down excruciatingly slowly, but if I take the handle down farther it slams down all at once.
Any ideas/help would be greatly appreciated. I have a shop manual but it doesn't really address this particular situation. I have adjusted the lift spring according to the manual, but nothing I've done with it will get the lift quadrant anywhere near the way it's supposed to be. The manual states the lift handle all the way up should be in the transport position and it should begin to lower about 2 1/2 inches from the top. All my lifting is happening in the lower fourth of the handle quadrant.
