Whether or not to use ethanol is about as hotly debated as what oil should you be using, and in both cases, it is largely a matter of opinion and personal preference. If you are using the tractor fairly regularly, you will not notice any issues as you are going through the gas fairly quickly. Issues begin to appear if the gas sits in the carb and tank for an extended time. Now let's be clear on one thing, while ethanol will evaporate and leave behind a residue, so will regular gas, ethanol just does so a little more quickly because of the lower evaporation point of alcohol as opposed to gas. So the biggest concern with ethanol, as is with regular gas, is leaving it for an extended period. As most gas tanks on our old tractor are not airtight, the fuel can evaporate. But with ethanol, you can have fuel left in your tank, and although it may not smell bad like regular gas is known to do, it can be absolutely useless. The ethanol can all evaporate out of the fuel and if you drain it into a can, you could drop a farmer's match into it and the fuel would snuff it out when it sunk into it.
Now there will be those who tell you that ethanol will destroy rubber O-rings and other rubber components in a carburetor, but that is open to disagreement, but a single barrel DLTX carb found on letter series John Deere has machine fit metal parts, so that isn't much of a concern. The two barrel ones found on the following two cylinder number series may be the same, but I haven't torn into them enough to know for sure.
So running your tractor on ethanol will not hurt it, you just have to be contentious about draining out the fuel when it is not in use for some time, just a little more so when you use ethanol. And of course, additives like Sta-bil or Sea Foam help address that issue as well as does running the carb out of fuel and opening the bowl drain as well as draining the tank.
