Ever try to straighten a tree?
ohfred
I got a tree that is between me and where the tractor is parked and it started growing straight and now grows 10 or 15 degrees toward the south. It is a white pine (I think)planted as a seedling and growing like a weed. Is there any way that I can force it to grow right? Like maybe a one inch turnbuckle against a dead man in the ground and give it a turn now and then. Anybody ever try it? It's about ten inches at the base now. The wife says its the ugliest tree she ever seen and it has to come down...help! ohfred
Is it leaning because of the direction of high winds? It doesn't have to be constant wind, just that when it gets high it is from the same direction. Lots of trees here in Kingman lean because of this.
Or, it is planted over an old outhouse hole. wink
Trees actually lean to where it can get the most sun. If you have two tall buildings side by side with a gap running north to south with a tree inbetween then the tree will lean to the south. A tree out in the open won't lean because it receives the sunlight evenly. In a forest trees go up to get the most sunlight which would explain why forest trees are so much taller than trees in the open and why trees in the open grow so much wider. I'm not sure what to tell you though because if it wants to grow to the south it will grow to the south unless you get whatever is in the way of the sun coming from the west and east out of the way.
Yep it will work. If you want to accelerate the process soak the ground opposite the lean with water for a few days. The ground will become like pudding and you can pull er right back into plumb.
Thanks for the comments on the leaning tree. I think I'll try to straighten it with your help of course...the comment about soaking the ground real good was something that I'd not thought of but, this clay out here is like concrete so, I don't know if it'll straighten or not. I'll give it a try. Maybe I ought to just get rid of the wife. That would save a lot of digging...especially in my pockets..wink. ohfred
