Excalibur 2 ton engine hoist
Mike(NEOhio)
Location
Newbury, Ohio
I need seals for the 8-ton long ram. The hoist is USA made but what was left of the label on the ram said China. Where can I get the parts or repair kit? I'm having no luck on Google.
A good bearing or hydraulic shop would probably have the seals and O-rings you want. You just need to take the old ones out and match them up. I have the same issue with a 4 ton floor jack, just have to match the O-rings.
The O-rings are really OK. What I need is the seal where the outer tube meets the base. It's an L-shaped cross section. I'm going to put it back together and see if it leaks. If it does I'll just get that $32 ram.
